Build(deps): Bump omniauth-oauth2 from 1.6.0 to 1.7.0 (PR #10412)
Bumps omniauth-oauth2 from 1.6.0 to 1.7.0.
Release notes
Sourced from omniauth-oauth2's releases.
Add strategy option for PKCE
v1.7.0 adds the option to specify that your strategy should utilize PKCE.
Simply add the pkce option to your strategy and set it to true:
option :pkce, true
By default, this uses the recommended code_challenge_method of "S256", but in the event that you want to use basic, or some other future code challenge method, you can specify them in your strategy as well:
option :pkce_options, {
  :code_challenge => proc { |verifier| verifier },
  :code_challenge_method => "basic",
Note that the code_challenge must be supplied in the form of something that responds to call.
Commits
GitHub
