Build(deps): Bump onebox from 1.9.27.1 to 1.9.27.2 (PR #9585)
Bumps onebox from 1.9.27.1 to 1.9.27.2.
Commits
GitHub
Looks like onebox is up-to-date now, so this is no longer needed.
