Build(deps): Bump onebox from 1.9.30 to 2.0.0 (PR #10235)
Bumps onebox from 1.9.30 to 2.0.0.
Commits
GitHub
@lis2 assume you need to do this by hand.
OK, I won’t notify you again about this release, but will get in touch when a new version is available. If you’d rather skip all updates until the next major or minor version, let me know by commenting @dependabot ignore this major version or @dependabot ignore this minor version.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
