Build(deps): Bump optimist from 3.0.0 to 3.0.1 (PR #9476)
Bumps optimist from 3.0.0 to 3.0.1.
Changelog
Sourced from optimist's changelog.
== [3.0.1] / 2020-04-20
Commits
GitHub
