Build(deps): Bump parser from 2.7.0.4 to 2.7.0.5 (PR #9247)
Bumps parser from 2.7.0.4 to 2.7.0.5.
Changelog
Sourced from parser's changelog.
v2.7.0.5 (2020-03-20)
Features implemented:
  • ruby27.y: fix array pattern with tail source map (#659) (Vladimir Dementyev)
Bugs fixed:
  • builder.rb: fix constant_pattern source map (#660) (Vladimir Dementyev)
Commits
GitHub
Looks like parser is up-to-date now, so this is no longer needed.
