Build(deps): Bump parser from 2.7.0.5 to 2.7.1.0 (PR #9347)
Bumps parser from 2.7.0.5 to 2.7.1.0.
Changelog
Sourced from parser's changelog.
v2.7.1.0 (2020-04-03)
API modifications:
  • Bump ruby versions to 2.4.10, 2.5.8, 2.6.6, 2.7.1. (#665) (Ilya Bylich)
Features implemented:
  • ruby27.y: allow newlines inside braced pattern. (#664) (Ilya Bylich)
  • ruby27.y: Allow trailing comma in hash pattern (#661) (Koichi ITO)
Commits
GitHub
