Build(deps): Bump parser from 2.7.1.0 to 2.7.1.1 (PR #9425)
Bumps parser from 2.7.1.0 to 2.7.1.1.
Changelog
Sourced from parser's changelog.
Changelog
Not released (2020-04-15)
Features implemented:
  • Add Source::Range#eql? and hash (#675) (Marc-André Lafortune)
  • Source::TreeRewriter: Add #merge, #merge! and #empty? (#674) (Marc-André Lafortune)
Commits
GitHub
