Build(deps): Bump parser from 2.7.1.1 to 2.7.1.2 (PR #9602)
Bumps parser from 2.7.1.1 to 2.7.1.2.
Changelog
Sourced from parser's changelog.
Changelog
Not released (2020-04-30)
Features implemented:
  • ruby28.y: endless method definition (#676) (Vladimir Dementyev)
  • ruby28.y: branch parser (#677) (Vladimir Dementyev)
Bugs fixed:
  • ruby27.y: reject invalid lvar in pattern matching (#680) (Vladimir Dementyev)
Commits
GitHub
