Build(deps): Bump parser from 2.7.1.2 to 2.7.1.3 (PR #9884)
Bumps parser from 2.7.1.2 to 2.7.1.3.
Changelog
Sourced from parser's changelog.
v2.7.1.3 (2020-05-26)
API modifications:
  • fixed all warnings. tests are running in verbose mode now. (#685) (Ilya Bylich)
Features implemented:
  • ruby-[parse, rewrite]: add legacy switches (#699) (Marc-André Lafortune)
  • Added Parser::Source::Range#to_range. (#697) (Ilya Bylich)
  • ruby28.y: support rescue modifier in endless method definition. (#696) (Ilya Bylich)
  • ruby28.y: unify kwrest and no-kwrest rules. (#694) (Ilya Bylich)
  • ruby28.y: add right hand assignment (#682) (Vladimir Dementyev)
Bugs fixed:
  • fix Comment.associate for postfix conditions/loops (#688) (Marc-André Lafortune)
Commits
  • 90fff17 Update changelog.
  • 999c09b Bump version.
  • 996c820 + ruby-[parse, rewrite]: add legacy switches (#699)
  • 521054b update travis matrix (add truffleruby, remove rubinius) (#695)
  • cbbb6bb make sure that all nodes are known for AST::Processor. (#698)
  • 54da73c + Added Parser::Source::Range#to_range. (#697)
  • ea787b5 + ruby28.y: support rescue modifier in endless method definition. (#696)
  • 742db78 + ruby28.y: unify kwrest and no-kwrest rules. (#694)
  • de200f1 - fix Comment.associate for postfix conditions/loops (#688)
  • 2b60937 Allow creating of Buffer with source (#693)
  • Additional commits viewable in compare view
GitHub
