Build(deps): Bump parser from 2.7.1.3 to 2.7.1.4 (PR #10096)
Bumps parser from 2.7.1.3 to 2.7.1.4.
Changelog
Sourced from parser's changelog.
v2.7.1.4 (2020-06-19)
Features implemented:
  • ruby28.y: add find pattern. (#714) (Ilya Bylich)
  • lexer.rl: reject ->... and ->(...) with the same error. (#713) (Ilya Bylich)
  • ruby28.y: accept leading args before forward arg. (#712) (Ilya Bylich)
  • Added emit_forward_arg compatibility flag. (#710) (Ilya Bylich)
  • ruby28.y: include entire lambda expr in lambda rule. (#708) (Ilya Bylich)
  • ruby28.y: extracted excessed_comma rule. (#706) (Ilya Bylich)
  • Source::TreeRewriter: Improved merging and representations (#703) (Marc-André Lafortune)
Bugs fixed:
  • ruby*.y: fixed context inside lambda args and module. (#709) (Ilya Bylich)
Commits
  • 7d1490e Update changelog.
  • a3c7250 Bump version.
  • f03d763 + ruby28.y: add find pattern. (#714)
  • c56ca2f + lexer.rl: reject ->... and ->(...) with the same error. (#713)
  • c215622 + ruby28.y: accept leading args before forward arg. (#712)
  • c776771 + Added emit_forward_arg compatibility flag. (#710)
  • bc20734 - ruby*.y: fixed context inside lambda args and module. (#709)
  • b5c1fb4 + ruby28.y: include entire lambda expr in lambda rule. (#708)
  • 3178e3f Speed up truffleruby on CI. (#707)
  • fccc653 + ruby28.y: extracted excessed_comma rule. (#706)
  • Additional commits viewable in compare view
GitHub
