Build(deps): Bump parser from 2.7.1.4 to 2.7.1.5 (PR #10741)
Bumps parser from 2.7.1.4 to 2.7.1.5.
Changelog
Sourced from parser's changelog.
v2.7.1.5 (2020-09-24)
API modifications:
  • right assignment: use existing AST node types (#738) (#739) (Marc-André Lafortune)
  • ruby28.y -> ruby30.y (#729) (Vladimir Dementyev)
Features implemented:
  • Optimize Range#column_range (#741) (Marc-André Lafortune)
  • ruby30.y: reject endless setter. (#736) (Ilya Bylich)
  • ruby28.y: reject assignment to numparam. (#725) (Ilya Bylich)
  • emit "endless method def" as :def node. (#716) (Ilya Bylich)
Bugs fixed:
  • rename 2.8 to 3.0 everywhere (#732) (Ilya Bylich)
  • test_current.rb: 2.8 -> 3.0 (#731) (Vladimir Dementyev)
  • Parser#parse returns nil instead of false if error is thrown (#722) (Marc-André Lafortune)
  • unify locations for normal and endless method definition (#718) (Marc-André Lafortune)
  • ruby27.y: accept const names as hash keys for pattern matching (#717) (Koichi ITO)
  • Fix locations for alias / undef nodes with internal symbols (#715) (Marc-André Lafortune)
Commits
GitHub
