Build(deps): Bump parser from 2.7.1.5 to 2.7.2.0 (PR #10843)
Bumps parser from 2.7.1.5 to 2.7.2.0.
Changelog
Sourced from parser's changelog.
v2.7.2.0 (2020-10-06)
API modifications:
  • Bump 2.7 branch to 2.7.2 (#748) (Koichi ITO)
Commits
GitHub
