Bumps parser from 3.0.0.0 to 3.0.1.0.
Changelog
Sourced from parser's changelog.
v3.0.1.0 (2021-04-06)
API modifications:
- Bump maintenance branches to 3.0.1, 2.7.3, 2.6.7, and 2.5.9 (#791) (Koichi ITO)
Features implemented:
Commits
Dependabot will resolve any conflicts with this PR as long as you don’t alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase
@dependabot rebase
will rebase this PR -
@dependabot recreate
will recreate this PR, overwriting any edits that have been made to it -
@dependabot merge
will merge this PR after your CI passes on it -
@dependabot squash and merge
will squash and merge this PR after your CI passes on it -
@dependabot cancel merge
will cancel a previously requested merge and block automerging -
@dependabot reopen
will reopen this PR if it is closed -
@dependabot close
will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
