Build(deps): Bump parser from 3.0.1.1 to 3.0.2.0 (PR #13672)
Bumps parser from 3.0.1.1 to 3.0.2.0.
Changelog
Sourced from parser's changelog.
v3.0.2.0 (2021-07-08)
API modifications:
  • Bump maintenance branches to 3.0.2, 2.7.4, and 2.6.8 (#805) (Koichi ITO)
Features implemented:
  • lexer.rl: reject \u after control/meta escape chars. (#807) (Ilya Bylich)
  • ruby31.y: allow "command" syntax in endless method definition (#801) (Koichi ITO)
Commits
GitHub
