Build(deps): Bump parser from 3.0.2.0 to 3.0.3.0 (PR #15099)
Bumps parser from 3.0.2.0 to 3.0.3.0.
Changelog
Sourced from parser's changelog.
v3.0.3.0 (2021-11-25)
API modifications:
  • Bump maintenance branches to 3.0.3, 2.7.5, and 2.6.9 (#829) (Koichi ITO)
Features implemented:
  • lexer.rl: parse meta-control-hex chars in regexes starting from 3.1 (#828) (Ilya Bylich)
  • builder.rb: warn on duplicate hash key literals. (#827) (Ilya Bylich)
  • ruby31.y: Allow value omission in Hash literals (#818) (Svyatoslav Kryukov)
  • ruby31.y: Allow omission of parentheses in one line pattern matching (#816) (Koichi ITO)
  • ruby31.y: Add pattern matching pin support for instance/class/global variables (#813) (Koichi ITO)
Bugs fixed:
  • ruby31.y: handle local variables as hash labels with omitted values (#820) (Ilya Bylich)
  • lexer.rl: Fix handling of beginless ranges at start of line (#822) (Matijs van Zuijlen)
  • dedenter.rb: Fix squiggly heredoc line continuation handling (#819) (Matijs van Zuijlen)
  • lexer.rl: fix incompatible delimiters on percent literal (#808) (Masataka Pocke Kuwabara)
Commits
  • dd268b9 Update changelog.
  • 3cfcb80 Bump version.
  • 2479b90 * Bump maintenance branches to 3.0.3, 2.7.5, and 2.6.9 (#829)
  • 24d2f68 + lexer.rl: parse meta-control-hex chars in regexes starting from 3.1 (#828)
  • 547d731 + builder.rb: warn on duplicate hash key literals. (#827)
  • 57bd371 - ruby31.y: handle local variables as hash labels with omitted values (#820)
  • bc8582c - lexer.rl: Fix handling of beginless ranges at start of line (#822)
  • 0f1c7d7 add tests for keyword argument value omission (#821)
  • 61bf873 - dedenter.rb: Fix squiggly heredoc line continuation handling (#819)
  • 22e6ca5 + ruby31.y: Allow value omission in Hash literals (#818)
  • Additional commits viewable in compare view
GitHub
