Build(deps): Bump path-parse from 1.0.6 to 1.0.7 in /support/text-unicode-webpack (PR #21)
Bumps path-parse from 1.0.6 to 1.0.7.
Commits
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
