Build(deps): Bump progress from 3.5.2 to 3.6.0 (PR #12596)
Bumps progress from 3.5.2 to 3.6.0.
Changelog
Sourced from progress's changelog.
v3.6.0 (2021-04-02)
  • Use Process.clock_gettime instead of Time.now which is faster and should give proper estimates even if sleeping in the middle #13 @​toy
Commits
GitHub
