Build(deps): Bump public_suffix from 4.0.3 to 4.0.4 (PR #9353)
Bumps public_suffix from 4.0.3 to 4.0.4.
Changelog
Sourced from public_suffix's changelog.
4.0.4
Changed
  • Updated definitions.
Commits
GitHub
