Build(deps): Bump puma from 4.3.3 to 4.3.4 (PR #9824)
Bumps puma from 4.3.3 to 4.3.4.
Changelog
Sourced from puma's changelog.
5.0.0
  • Features
    • EXPERIMENTAL: Add fork_worker option and refork command for reduced memory usage by forking from a worker process instead of the master process. (#2099)
    • EXPERIMENTAL: Added wait_for_less_busy_worker config. This may reduce latency on MRI through inserting a small delay before re-listening on the socket if worker is busy (#2079).
    • EXPERIMENTAL: Added nakayoshi_fork option. Reduce memory usage in preloaded cluster-mode apps by GCing before fork and compacting, where available. (#2093, #2256)
    • Added pumactl thread-backtraces command to print thread backtraces (#2054)
    • Added incrementing requests_count to Puma.stats. (#2106)
    • Increased maximum URI path length from 2048 to 8196 bytes (#2167)
    • lowlevel_error_handler is now called during a forced threadpool shutdown, and if a callable with 3 arguments is set, we now also pass the status code (#2203)
    • Faster phased restart and worker timeout (#2220)
    • Added state_permission to config DSL to set state file permissions (#2238)
    • Added Puma.stats_hash, which returns a stats in Hash instead of a JSON string (#2086, #2253)
  • Deprecations, Removals and Breaking API Changes
    • --control has been removed. Use --control-url (#1487)
    • worker_directory has been removed. Use directory.
    • min_threads now set by environment variables PUMA_MIN_THREADS and MIN_THREADS. (#2143)
    • max_threads now set by environment variables PUMA_MAX_THREADS and MAX_THREADS. (#2143)
    • max_threads default to 5 in MRI or 16 for all other interpreters. (#2143)
    • preload by default if workers > 1 (#2143)
    • Puma::Plugin.workers_supported? has been removed. Use Puma.forkable? instead. (#2143)
    • tcp_mode has been removed without replacement. (#2169)
    • Daemonization has been removed without replacement. (#2170)
    • Changed #connected_port to #connected_ports (#2076)
    • Configuration: environment is read from RAILS_ENV, if RACK_ENV can't be found (#2022)
  • Bugfixes
    • Close client http connections made to an ssl server with TLSv1.3 (#2116)
    • Do not set user_config to quiet by default to allow for file config (#2074)
    • Always close SSL connection in Puma::ControlCLI (#2211)
    • Windows update extconf.rb for use with ssp and varied Ruby/MSYS2 combinations (#2069)
    • Ensure control server Unix socket is closed on shutdown (#2112)
    • Preserve BUNDLE_GEMFILE env var when using prune_bundler (#1893)
    • Send 408 request timeout even when queue requests is disabled (#2119)
    • Rescue IO::WaitReadable instead of EAGAIN for blocking read (#2121)
    • Ensure BUNDLE_GEMFILE is unspecified in workers if unspecified in master when using prune_bundler (#2154)
    • Rescue and log exceptions in hooks defined by users (on_worker_boot, after_worker_fork etc) (#1551)
    • Read directly from the socket in #read_and_drop to avoid raising further SSL errors (#2198)
    • Set Connection: closed header when queue requests is disabled (#2216)
    • Pass queued requests to thread pool on server shutdown (#2122)
    • Fixed a few minor concurrency bugs in ThreadPool that may have affected non-GVL Rubies (#2220)
    • Fix out_of_band hook never executed if the number of worker threads is > 1 (#2177)
    • Fix ThreadPool#shutdown timeout accuracy (#2221)
    • Fix UserFileDefaultOptions#fetch to properly use default (#2233)
    • Improvements to out_of_band hook (#2234)
    • Prefer the rackup file specified by the CLI (#2225)
  • Refactor
    • Remove unused loader argument from Plugin initializer (#2095)
... (truncated)
Commits
GitHub
