Build(deps): Bump puma from 5.0.0 to 5.0.2 (PR #10763)
Bumps puma from 5.0.0 to 5.0.2.
Release notes
Sourced from puma's releases.
5.0.1
This release fixed a critical error for CentOS users, and quieted some unnecessary error logging for Heroku users.
  • Bugfixes
    • Fix LoadError in CentOS 8 (#2381)
    • Better error handling during force shutdown (#2271)
    • Prevent connections from entering Reactor after shutdown begins (#2377)
    • Fix error backtrace debug logging && Do not log request dump if it is not parsed (#2376)
    • Split TCP_CORK and TCP_INFO (#2372)
    • Do not log EOFError when a client connection is closed without write (#2384)
  • Refactor
    • Change Events#ssl_error signature from (error, peeraddr, peercert) to (error, ssl_socket) (#2375)
    • Consolidate option handling in Server, Server small refactors, doc chang (#2373)
Changelog
Sourced from puma's changelog.
5.0.2 / 2020-09-28
  • Bugfixes
    • Reverted API changes to Server.
5.0.1 / 2020-09-28
  • Bugfixes
  • Refactor
Commits
GitHub
