Build(deps): Bump puma from 5.3.0 to 5.3.1 (PR #13038)
Bumps puma from 5.3.0 to 5.3.1.
Changelog
Sourced from puma's changelog.
5.3.1 / 2021-05-11
  • Security
    • Close keepalive connections after the maximum number of fast inlined requests (#2625)
Commits
GitHub
