Build(deps): Bump puma from 5.3.1 to 5.3.2 (PR #13119)
Bumps puma from 5.3.1 to 5.3.2.
Changelog
Sourced from puma's changelog.
5.3.2 / 2021-05-21
  • Bugfixes
    • Gracefully handle Rack not accepting CLI options (#2630, #2626)
    • Fix sigterm misbehavior (#2629)
    • Improvements to keepalive-connection shedding (#2628)
Commits
GitHub
