Build(deps): Bump puma from 5.3.2 to 5.4.0 (PR #13891)
Bumps puma from 5.3.2 to 5.4.0.
Release notes
Sourced from puma's releases.
5.4.0 - Super Flight
![CasiopeaSuperFlightalbumcover](upload://w3nLapqiSU92eBFMFOqpwxOj420.jpeg)
  • Features
    • Better/expanded names for threadpool threads (#2657)
    • Allow pkg_config for OpenSSL (#2648, #1412)
    • Add rack_url_scheme to Puma::DSL, allows setting of rack.url_scheme header (#2586, #2569)
  • Bugfixes
    • Binder#parse - allow for symlinked unix path, add create_activated_fds debug ENV (#2643, #2638)
    • Fix deprecation warning: minissl.c - Use Random.bytes if available (#2642)
    • Client certificates: set session id context while creating SSLContext (#2633)
  • Refactor
    • Replace IO.select with IO#wait_* when checking a single IO (#2666)
Changelog
Sourced from puma's changelog.
5.4.0 / 2021-07-28
  • Features
  • Bugfixes
  • Refactor
Commits
GitHub
