Build(deps): Bump rack-mini-profiler from 2.0.1 to 2.0.2 (PR #9865)
Bumps rack-mini-profiler from 2.0.1 to 2.0.2.
Changelog
Sourced from rack-mini-profiler's changelog.
2.0.2 - 2020-05-25
  • [FIX] client timings were not showing up when you clicked show trivial
Commits
  • 44b01ff DEV: new release
  • 4543ed2 FIX: Fix client timings regression and bring back 'show trivial' (#441)
  • 2594524 DEV: Quality of life improvements when working on MP client-side code (#443)
  • See full diff in compare view
GitHub
