Build(deps): Bump rack-mini-profiler from 2.0.2 to 2.0.3 (PR #10331)
Bumps rack-mini-profiler from 2.0.2 to 2.0.3.
Changelog
Sourced from rack-mini-profiler's changelog.
2.0.3 - 2020-07-29
  • [FIX] support for deprecation free Redis 4.2
  • [FEATURE] skip /packs when serving static assets
  • [FEATURE] allow Net::HTTP patch to be applied with either prerpend or alias
Commits
  • 6b03139 Updated sassc which triggered an asset version change
  • 4afeb1e Changelog and version bump
  • 60fb0d5 DEV: Fix our Travis build (#455)
  • 7ad4279 DEV: Remove Redis 4.2 warnings. (#450)
  • cea53b8 Fix specs. (#454)
  • 47a8a59 Fix false 404 in logs when visiting /rack-mini-profiler/requests (#453)
  • 029854f Replace stale recipe for custom middleware ordering with description of curre...
  • c8b19a4 Correct documentation for skip_schema_queries
  • 4d5839d FEATURE: Skip "/packs" when serving static assets (#447)
  • c42c190 DEV: Ruby 2.3. support has been dropped since 1.0.1. (#449)
  • Additional commits viewable in compare view
GitHub
