Build(deps): Bump rack-mini-profiler from 2.0.3 to 2.0.4 (PR #10362)
Bumps rack-mini-profiler from 2.0.3 to 2.0.4.
Changelog
Sourced from rack-mini-profiler's changelog.
2.0.4 - 2020-08-04
  • [FIX] webpacker may exist with no config, allow for that
Commits
  • 0082fc0 Version bump
  • 7453c58 FIX: Check for Webpacker config file existence before trying to access the co...
  • See full diff in compare view
GitHub
does not impact us, very safe update
