Build(deps): Bump rack-mini-profiler from 2.0.4 to 2.1.0 (PR #10686)
Bumps rack-mini-profiler from 2.0.4 to 2.1.0.
Changelog
Sourced from rack-mini-profiler's changelog.
2.1.0 - 2020-09-17
  • [FEATURE] Allow assets to be precompiled with Sprockets
  • [FEATURE] Snapshots sampling (see README in repo)
  • [FEATURE] Allow skip_paths config to contain regular expressions
Commits
GitHub
