Build(deps): Bump rack-mini-profiler from 2.3.1 to 2.3.2 (PR #12911)
Bumps rack-mini-profiler from 2.3.1 to 2.3.2.
Changelog
Sourced from rack-mini-profiler's changelog.
2.3.2 - 2021-04-30
  • [FEATURE] Introduce pp=async-flamegraph for asynchronous flamegraphs
Commits
  • 338cdd1 bump asset version
  • ad171ff Bump new version
  • 020cd4f FEATURE: Introduce pp=async-flamegraph for asynchronous flamegraphs (#494)
  • aef9b23 Fix profiler pop-up extending beyond the window, impossible to scroll (#492)
  • 0a31c78 DEV: minor avoid ruby and rubocop warnings
  • e99b44d FEATURE: rename whitelist to allow_authorized
  • 94670b7 Add memory_profiler error when not installed (#488)
  • cfbcf5d README: Fix typo (#486)
  • 55ba4c4 Remove obsolete Ruby version requirement notes (#484)
  • See full diff in compare view
GitHub
