Build(deps): Bump rack-mini-profiler from 2.3.2 to 2.3.3 (PR #14192)
Bumps rack-mini-profiler from 2.3.2 to 2.3.3.
Changelog
Sourced from rack-mini-profiler's changelog.
2.3.3 - 2021-08-30
  • [FEATURE] Introduce pp=flamegraph_mode
  • [FEATURE] Richer CSP configuration options
  • [FEATURE] Add support for Hotwire Turbo Drive
Commits
  • e384187 version bump
  • bfcbe59 Link github project on ?pp=help menu (#510)
  • 3d3b430 Add flamegraph_mode config option and query string parameter (#508)
  • 5f29900 Fix rubocop offense
  • 3f47ae9 Add a note to the README about SQL timings absence when generating flamegraph...
  • 4e6d463 Remove old css (#505)
  • 54c8db6 DOCS: Improve development section from Readme.md (#502)
  • 1f8b391 FEATURE: Add support for Hotwire Turbo Drive (#498)
  • 6cadc08 Allow content-type header with charset on test. (#501)
  • a93060e FIX: Add charset=utf-8 to content-type text/plain (#497)
  • Additional commits viewable in compare view
GitHub
