Build(deps): Bump rails_failover from `66602aa` to `23a56b5` (PR #10045)
Bumps rails_failover from 66602aa to 23a56b5.
Commits
  • 23a56b5 FEATURE: Rescue and log errors when running callbacks.
  • 8dd9365 rails_failover should be require: false by default.
  • 5901379 Revert "FIX: Remove automatic failover on boot."
  • deb9ff1 FIX: Remove automatic failover on boot.
  • See full diff in compare view
GitHub
@dependabot rebase
Looks like rails_failover is up-to-date now, so this is no longer needed.
