Build(deps): Bump rails_failover from `66602aa` to `5901379` (PR #10024)
Bumps rails_failover from 66602aa to 5901379.
Commits
  • 5901379 Revert "FIX: Remove automatic failover on boot."
  • deb9ff1 FIX: Remove automatic failover on boot.
  • See full diff in compare view
GitHub
Superseded by #10045.
