Build(deps): Bump rails-html-sanitizer from 1.4.1 to 1.4.2 (PR #14135)
Bumps rails-html-sanitizer from 1.4.1 to 1.4.2.
Release notes
Sourced from rails-html-sanitizer's releases.
1.4.2 / 2021-08-23
  • Slightly improve performance.
    Assuming elements are more common than comments, make one less method call per node.
Changelog
Sourced from rails-html-sanitizer's changelog.
1.4.2 / 2021-08-23
    Mike Dalessio
Commits
  • c86fed1 version bump to v1.4.2
  • d494309 Merge pull request #118 from rails/flavorjones-tweak-comment-and-pi
  • b1fe437 perf: PermitScrubber#scrub checks node.element? before node.comment?
  • ab21d78 test: rewrite test coverage for comments and PIs
  • db9ccec ci: update default git branch
  • 97099c0 Merge pull request #119 from rails/flavorjones-port-ci-to-github-actions
  • e73f3e9 ci: remove travis and update the CI badge
  • 8d3db92 ci: add github actions workflow
  • See full diff in compare view
GitHub
