Build(deps): Bump rails_multisite from 2.4.0 to 2.5.0 (PR #10689)
Bumps rails_multisite from 2.4.0 to 2.5.0.
GitHub
Looks like rails_multisite is up-to-date now, so this is no longer needed.
