Build(deps): Bump rails_multisite from 2.5.0 to 3.0.0 (PR #12514)
Bumps rails_multisite from 2.5.0 to 3.0.0.
GitHub
I am closing this and letting @OsamaSayegh take care of the upgrade with the Rails update.
OK, I won’t notify you again about this release, but will get in touch when a new version is available.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
