Build(deps): Bump rake-compiler from 1.1.0 to 1.1.1 (PR #10206)
Bumps rake-compiler from 1.1.0 to 1.1.1.
Changelog
Sourced from rake-compiler's changelog.
=== 1.1.1 / 2020-07-10
  • Changes:
    • Bump the default Java bytecode to 1.7. #172 [Patch by Charles Oliver Nutter]
  • Enhancements:
    • Add support for finding x86_64 MinGW GCC. #164 [Patch by Lars Kanis]
    • Strip cross compiled shared library automatically. #165 [Patch by Lars Kanis]
Commits
GitHub
