Build(deps): Bump rbtrace from 0.4.13 to 0.4.14 (PR #10361)
Bumps rbtrace from 0.4.13 to 0.4.14.
Commits
  • ecb2b53 cut a new release
  • 7aee201 Native extension: include ruby/debug.h for rb_postponed_job_register_one prot...
  • 4b6b80c Merge pull request #80 from ZimbiX/fix-gem-require-in-termux-on-android
  • 5b18f29 Fix require failing in Termux on Android
  • aff85bb Merge pull request #79 from casperisfine/fix-ruby-head-deprecations
  • 3afe0ea Fix ruby 2.8/3.0 deprecations about File.exists?
  • See full diff in compare view
GitHub
minor changes, no real risk with this update
