Build(deps): Bump redis from 4.1.3 to 4.1.4 (PR #9608)
Bumps redis from 4.1.3 to 4.1.4.
Changelog
Sourced from redis's changelog.
4.1.4
  • Alias Redis#disconnect as #close. See #901.
  • Handle clusters with multiple slot ranges. See #894.
  • Fix password authentication to a redis cluster. See #889.
  • Handle recursive MOVED responses. See #882.
  • Increase buffer size in the ruby connector. See #880.
  • Fix thread safety of Redis.queue. See #878.
  • Deprecate Redis::Future#== as it's likely to be a mistake. See #876.
Commits
  • 46e95a4 Release 4.1.4
  • 5694b00 Merge pull request #901 from mperham/patch-2
  • 55a9106 Implement close method
  • c97f10c Merge pull request #899 from isqad/fix/empty_string
  • 166593d feature: add frozen_string_literal: true comment
  • 4df7350 Merge pull request #897 from 007lva/chore/replace-Fixnum-with-Integer-in-docs
  • eaa3b33 Replace Fixnum with in Integer in methods docs
  • 45666da Merge pull request #896 from supercaracal/fix-a-unstable-test-case
  • a165deb Since Sentinel keeps monitoring by ping, change commandstats key for test.
  • 3b8495e Fix a unstable test case and resolve #895
  • Additional commits viewable in compare view
GitHub
