Build(deps): Bump redis from 4.2.1 to 4.2.2 (PR #10622)
Bumps redis from 4.2.1 to 4.2.2.
Changelog
Sourced from redis's changelog.
4.2.2
  • Fix WATCH support for Redis::Distributed. See #941.
  • Fix handling of empty stream responses. See #905, #929.
Commits
  • cf44d71 Release 4.2.2
  • 3a37377 Disable GitHub Actions fail-fast
  • 69ce376 Merge pull request #941 from EiNSTeiN-/watch-support-redis-disributed
  • 3aac4e9 Merge pull request #937 from supercaracal/fix-ssl-test-issue
  • 9b4a885 Merge pull request #930 from supercaracal/fix-unstable-test-cases
  • bd6de9f Lint
  • d87871f Catch all exceptions in watch block
  • 655736f transaction support for redis distributed
  • 8743bfe Fix SSL test issue and resolve #932
  • 898c8a6 Fix bad English sentence
  • Additional commits viewable in compare view
GitHub
