Build(deps): Bump redis from 4.3.1 to 4.4.0 (PR #13875)
Bumps redis from 4.3.1 to 4.4.0.
Changelog
Sourced from redis's changelog.
4.4.0
  • Redis cluster: fix cross-slot validation in pipelines. Fix ##1019.
  • Add support for XAUTOCLAIM. See #1018.
  • Properly issue READONLY when reconnecting to replicas. Fix #1017.
  • Make del a noop if passed an empty list of keys. See #998.
  • Add support for ZINTER. See #995.
Commits
  • 5dd7df9 Release 4.4.0
  • a200ee3 Merge pull request #1020 from supercaracal/fix-a-validation-bug-for-pipelinin...
  • 691aef7 Update test/cluster_client_pipelining_test.rb
  • 25715d5 Fix a bug for cross-slot validation for pipelining
  • baf5706 Merge pull request #1018 from vavato-be/add-xautoclaim
  • 73870ec add XAUTOCLAIM command, added to Redis in 6.2
  • ae80708 Issue READONLY as part of the client connection
  • 01768da Handle delete of empty list of keys (#998)
  • 7bb6b63 Merge pull request #995 from SkipKayhil/add-zinter
  • 68fe7b5 add ZINTER command, added to Redis in 6.2
  • See full diff in compare view
GitHub
