Build(deps): Bump redis-namespace from 1.7.0 to 1.8.0 (PR #10498)
Bumps redis-namespace from 1.7.0 to 1.8.0.
Changelog
Sourced from redis-namespace's changelog.
1.8.0
  • Fix Redis::Namespace#inspect to include the entire namespaced prefix.
  • Support variadic exists and exists?.
Commits
  • 30526eb Prepare to 1.8.0
  • 8e7f45e Merge pull request #171 from Tolsto/feature/new-exists-api
  • c8b6764 Merge pull request #169 from casperisfine/ruby-2.7
  • cc09dc3 Support variadic exists and exists?
  • 17a7d35 Test against ruby 2.7
  • 27abd8b Merge pull request #164 from woarewe/improvements/add-nested-namespaces-to-in...
  • e282846 Add final namespace prefix to inspect
  • 54066a5 Add project metadata to the gemspec (#168)
  • See full diff in compare view
GitHub
