Build(deps): Bump regexp_parser from 1.7.1 to 1.8.0 (PR #10710)
Bumps regexp_parser from 1.7.1 to 1.8.0.
Changelog
Sourced from regexp_parser's changelog.
[1.8.0] - 2020-09-20 - Janosch Müller
Changed
  • dropped support for running on Ruby 1.9.x
Added
  • regexp flags can now be passed when parsing a String as regexp body
  • bare occurrences of \g and \k are now allowed and scanned as literal escapes
Fixed
  • fixed parsing comments without preceding space or trailing newline in x-mode
Commits
  • bae4ea0 Release v1.8.0
  • d109b56 Merge pull request #68 from owst/allow_options_when_parsing_strings
  • eea67dd fixup! Allow options to be passed when processing a String pattern
  • 7c4d268 Allow options to be passed when processing a String pattern
  • 84b5650 Support \g, \k without group id as literal escapes
  • 74856d9 Let travis build all branches
  • 58a00d6 Merge pull request #67 from owst/allow_no_whitespace_comments
  • 6085eb5 Allow no-whitespace and single-line comments (#66)
  • See full diff in compare view
GitHub
@dependabot rebase
