Build(deps): Bump regexp_parser from 1.8.0 to 1.8.1 (PR #10767)
Bumps regexp_parser from 1.8.0 to 1.8.1.
Changelog
Sourced from regexp_parser's changelog.
[1.8.1] - 2020-09-28 - Janosch Müller
Fixed
  • fixed scanning of comment-like text in normal mode
    • this was an old bug, but had become more prevalent in v1.8.0
    • thanks to Tietew for the report
  • specified correct minimum Ruby version in gemspec
    • it said 1.9 but really required 2.0 as of v1.8.0
Commits
  • 58f3374 Release v1.8.1
  • 1d36045 Fix scanning of comment-like text in normal mode ...
  • 1808959 Specify correct minimum ruby after 7c4d268
  • See full diff in compare view
GitHub
