Build(deps): Bump rotp from 5.1.0 to 6.0.0 (PR #9530)
Bumps rotp from 5.1.0 to 6.0.0.
Changelog
Sourced from rotp's changelog.
6.0.0
  • Dropping support for Ruby <2.3 (Major version bump)
  • Fix issue when using --enable-frozen-string-literal Ruby option #95 (jeremyevans)
  • URI Encoding fix #94 (ksuh90)
  • Update gems (rake, addressable)
  • Update Travis tests to include Ruby 2.7
Commits
  • 5cf31c2 Update Readme regarding 6.0 dropping Ruby <2.3
  • 97475a1 Merge pull request #85 from amandameng/patch-1
  • 7af6858 Add in encoding fix for 6.0.0
  • 8ae63a8 Merge branch 'uri-encode-issuer' of https://github.com/ksuh90/rotp into ksuh9...
  • dd1e55b Update dependencies, remove Ruby <2.3 support
  • 5ec60df Fix issue when using --enable-frozen-string-literal Ruby option
  • a0ae135 URI encode the issuer parameter value
  • 5149825 Fix sample code
  • 4b22b7e Merge pull request #89 from olleolleolle/patch-1
  • 885187b gemspec: Drop EOL'd rubyforge_project property
  • Additional commits viewable in compare view
GitHub
@featheredtoast the test failures seem to be because they’ve switched from + to %20 which should be the same. Do you think you could update the tests and this lib?
Hmmm, I just checked this out - it seems to be double-encoding in the library, so issuers spaces appear as %2520 ( url encodes to %20, which in turn url encodes to %2520) which seems… unexpected.
While it’s probably safe enough and won’t break anything, it would look weird for some authenticators, and honestly sounds like there’s still a bug in the lib version here… I’d hold off personally.
