Build(deps): Bump rqrcode_core from 1.0.0 to 1.1.0 (PR #13610)
Bumps rqrcode_core from 1.0.0 to 1.1.0.
Release notes
Sourced from rqrcode_core's releases.
v1.1.0
https://github.com/whomwah/rqrcode_core/blob/master/CHANGELOG.md#110---2021-07-01
Changelog
Sourced from rqrcode_core's changelog.
[1.1.0] - 2021-07-01
  • Add a basic benchmark file
  • Add standardRB badge
  • Add .freeze on CONST lookup objects
  • Remove unused @mode instance variable
  • A batch of small refactors and optimizations
Commits
  • d053111 Merge pull request #24 from whomwah/dr-release-1-1-0
  • 4d0bb01 version 1.1.0
  • 7570f6b Merge pull request #22 from whomwah/dr-housekeeping
  • 8298b61 Tiny formatting changes and CHANGELOG update
  • c80a115 Simplify check for char in array
  • b335f7e Not convinced an extra method is required
  • 7cc4cdd Remove unused @​mode instance variable
  • 604e7e5 Target const without full path
  • 89a55d6 Remove unneeded data and add extra alphanumeric spec
  • 417cfac Add .freeze on CONST lookup objects
  • Additional commits viewable in compare view
GitHub
