Build(deps): Bump rqrcode from 2.0.0 to 2.1.0 (PR #14169)
Bumps rqrcode from 2.0.0 to 2.1.0.
Release notes
Sourced from rqrcode's releases.
v2.1.0
https://github.com/whomwah/rqrcode/blob/master/CHANGELOG.md#210---2021-08-26
Changelog
Sourced from rqrcode's changelog.
[2.1.0] - 2021-08-26
Changed
  • Corrected method name referred to in CHANGELOG.
Commits
  • e264a82 Merge pull request #120 from whomwah/dr-multimode-2.1.0
  • 9feb17c Bump release and sync to rqrcode_core 1.2.0
  • 75adef9 Merge pull request #119 from ebcagadas/master
  • fbf0864 Fix minor typo in README
  • 146447b Merge pull request #118 from whomwah/dr-standard
  • b1fe99d Add standard badge
  • 18e99ce Sync version in Gemfile.lock
  • 13d7713 Merge pull request #116 from nickhammond/patch-1
  • c2c4c35 Fix my previous commit!
  • d5e5df1 Update rqrcode.gemspec to fix linting
  • Additional commits viewable in compare view
GitHub
