Build(deps): Bump rspec-core from 3.9.1 to 3.9.2 (PR #9620)
Bumps rspec-core from 3.9.1 to 3.9.2.
Changelog
Sourced from rspec-core's changelog.
Development
Full Changelog
Bug Fixes:
  • Emit a warning when around hook is used with :context scope (Phil Pirozhkov, #2687)
  • Prevent invalid implementations of Exception#cause from being treated as a valid cause (and causing strange errors) in RSpec::Core::Formatters::ExceptionPresenter. (Jon Rowe, #2703)
  • Correctly detect patterns when rspec_opts is an array in RSpec::Core::RakeTask. (Marc-André Lafortune, #2704)
  • Make RSpec.clear_examples reset example counts for example groups. This fixes an issue with re-running specs not matching ids. (Agis Anastasopoulos, #2723)
Commits
  • d89b692 Version 3.9.2
  • a1b6ee2 Changelog for #2723
  • 16f21bd Merge pull request #2723 from agis/gh-2721-world-reset
  • c99129d Merge pull request #2719 from rspec/further-improve-kw-args-specs
  • ab52c5a Merge pull request #2718 from rspec/remove-klass-exec-in-favour-of-rspec-supp...
  • 5853848 Merge pull request #2715 from rspec/scenario-explaining-failures-dont-affect-...
  • abc6211 Merge pull request #2708 from rspec/add-default-hook-docs
  • 4803790 Sync build with master
  • edd1054 Prevent list from not being formatted by markdown parser in yard
  • 87fe9a2 Prevent list from not being formatted by markdown parser in yard
  • Additional commits viewable in compare view
GitHub
Looks like rspec-core is up-to-date now, so this is no longer needed.
