Build(deps): Bump rspec-expectations from 3.9.1 to 3.9.2 (PR #9732)
Bumps rspec-expectations from 3.9.1 to 3.9.2.
Changelog
Sourced from rspec-expectations's changelog.
3.9.2 / 2020-05-08
Full Changelog
Bug Fixes:
  • Issue a proper ArgumentError when invalid arguments are given to yield_control modifiers such as at_least et al. (Marc-André Lafortune, #1167)
  • Prevent Ruby 2.7 keyword arguments warning from being issued by custom matcher definitions. (Jon Rowe, #1176)
Commits
GitHub
