Build(deps): Bump rspec-support from 3.10.2 to 3.10.3 (PR #14812)
Bumps rspec-support from 3.10.2 to 3.10.3.
Changelog
Sourced from rspec-support's changelog.
3.10.3 / 2021-11-03
Full Changelog
Bug Fixes:
  • Use Mutex#owned? to allow RSpec::Support::ReentrantMutex to work in nested Fibers on Ruby 3.0 and later. (Benoit Daloze, #503, #504)
  • Support end-less methods in RSpec::Support::Source::Token so that RSpec won't hang when an end-less method raises an error. (Yuji Nakayama, #505)
Commits
  • be1feec v3.10.3
  • c13817f Merge pull request #520 from rspec/add-spec-for-source-token-one-liner
  • 0310777 Merge pull request #505 from rspec/support-end-less-methods-in-snippet-extractor
  • 25f4e3b Merge pull request #513 from rspec/update-ci-build-scripts-2021-07-13-for-3-1...
  • 1bcd561 Updated ci build scripts (from rspec-dev)
  • f28471d Merge pull request #509 from rspec/update-ci-build-scripts-2021-07-13-for-3-1...
  • 6097d53 Updated ci build scripts (from rspec-dev)3-10-maintenance
  • 77269e4 Merge pull request #504 from rspec/fix-reentrant-mutex-fiber-3.0
  • 835d085 Merge pull request #500 from rspec/update-ci-build-scripts-2021-04-23-for-3-1...
  • 92702cc Updated ci build scripts (from rspec-dev)3-10-maintenance
  • See full diff in compare view
GitHub
