Build(deps): Bump rspec-support from 3.9.2 to 3.9.3 (PR #9621)
Bumps rspec-support from 3.9.2 to 3.9.3.
Changelog
Sourced from rspec-support's changelog.
Development
Full Changelog
Bug Fixes:
  • Mark ripper as unsupported on Truffle Ruby. (Brandon Fish, #395)
  • Mark ripper as unsupported on JRuby 9.2.0.0. (Brian Hawley, #400)
  • Capture Mutex.new for our RSpec::Support:Mutex in order to allow stubbing Mutex.new. (Jon Rowe, #411)
Commits
GitHub
Looks like rspec-support is up-to-date now, so this is no longer needed.
