Build(deps): Bump rubocop-ast from 0.1.0 to 0.2.0 (PR #10263)
Bumps rubocop-ast from 0.1.0 to 0.2.0.
Changelog
Sourced from rubocop-ast's changelog.
0.2.0 (2020-07-19)
New features
  • #50: Support find pattern matching for Ruby 2.8 (3.0) parser. ([@koic][])
  • #55: Add ProcessedSource#line_with_comment?. ([@marcandre][])
  • #63: NodePattern now supports patterns as arguments to predicate and functions. ([@marcandre][])
  • #64: Add Node#global_const?. ([@marcandre][])
  • #28: Add struct_constructor?, class_definition? and module_definition? matchers. ([@tejasbubane][])
Bug fixes
  • #55: Fix ProcessedSource#commented? for multi-line ranges. Renamed contains_comment? ([@marcandre][])
Commits
  • 098529a Cut 0.2.0
  • 9e07813 [Fixes #67] Update cut_release for antora
  • 706dd72 Refactor cut_release.rake
  • e2df776 Add struct_constructor?, class_definition? and module_definition? matchers
  • 5ddb0cc CI: rename things a bit
  • e6ba39a CI: Split internal_investigation as its own CI job
  • 55ef778 DefNode: Optimize by avoiding intermediate array
  • 99e488f NodePattern: Reduce retained memory
  • 96aeca8 NodePattern: reduce memory allocations
  • 34798ca NodePattern: Avoid SimpleDelegator
  • Additional commits viewable in compare view
GitHub
